1 minute ago, sarggames said:
STOCK
For the ram and watch the caps
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325671
Just now, sarggames said:
STILL THE ISSUE
Did you take out the battery or actually shut off the power completely  (unplug from the wall and flick the psu switch to off) and then move the jumper to the other pins for 5 seconds then back?
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325672
2133
Try resetting the cmos and try have the ram at faster speed for the ram
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325680
i took the knife and shorted while power on as suggested in msi book
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325681
does it depends on ram 2133 is enough for it
Ryzen loves fast ram speeds so you need to OC them
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325696
48 minutes ago, sarggames said:
STOCK
Use HWinfo to read what the clock speeds on each of the cores and temperature are when under load.
Ram speed has next to no impact on cinebench performance. While is is a good idea for gaming to have fast RAM, if cinebench scores are low the issue is elsewhere.
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10325769
Maybe revealing the mobo model would help, but i maybe know. msi boards are reported to have a problem when CPU locks at 1550MHz after booting into windows and it can't be fixed and they are too dumb to figure it out and do a bios update i always recommend Asus boards
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/824481-ryzen-help/#findComment-10326305
