So I am returning for my second year studying game design and the primary programs we use are 3DS Max and UE4.  Due to "travel related trauma" my motherboards second RAM slot has just given up on life and my computer wouldn't even post if I had RAM in that slot.  For the past few months I've been running with 8Gb in one slot (which is fine for gaming over the summer) but in my first year I had 16Gb across the two slots.  I am wondering if I need to replace my motherboard so I can use 16Gb again or would 8Gb of RAM be enough for 3D modelling and game development in UE4, Photoshop etc. I assume it would be fine, especially since I really don't want to spend £129 on a brand new identical motherboard or around the same price for a single 16Gb stick of RAM at the same speed of my 2x8Gb. Any thoughts or whatever would be appreciated, thanks!
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/824353-3ds-max-ram-usage/
id stick with the 8GB for now, should be ok
Builds:
https://linustechtips.com/topic/824353-3ds-max-ram-usage/#findComment-10324144
The most I've ever been able to use in Autodesk or similar programs is a measly 18GB, so 16GB on one stick would get my vote unless you can replace the motherboard.
Edit: Just saw the "not suitable for dark theme" text. See if Asus can repair your board first.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/824353-3ds-max-ram-usage/#findComment-10324148
