I'm going to be making a custom case and I know for sure I'll be water cooling but I don't want to go over $500 cad (case costs less than $20 cad) and that's with tax and everything thing so I'm looking for a AIO with long tubes since the width of the custom case will be is 12" and it doesn't matter what colour but I know that I will be getting some fans from a local shop (120mm static pressure fans) so that limits the rad size to 120, 240 and a, 360mm rad so what AIO will be good for that with long tubes
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/823823-aio-with-long-tubes/
The NZXT Kraken unit have fairly long AIO tubes so they may be worth looking into.
https://linustechtips.com/topic/823823-aio-with-long-tubes/#findComment-10319784
Ok I'll look into them
https://linustechtips.com/topic/823823-aio-with-long-tubes/#findComment-10319846
