Hi i have an asus gtx 1060 oc that i just bought and have 5 monitors im looking at installing but before i purchase them, is it possible to do. I know it has 4 physical ports but i've heard around that it still only supports 4 so do/can i use the motherboard port considering only 3 displays will be for gamingand 2 will be for editing and other smaller tasks like movies. My cpu is an i5 4670 and and motherboard is a h81m+ thank you and please get back to me. Ilove you and all you do
https://linustechtips.com/topic/822953-multi-monitors/
why 5 monitors?
you should be able to use all 4 ports on your GPU, and you should be able to plug in one into your motherboard to get a display output too. thanks intel and laptops with display output!
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309779
You would just need to enable the iGPU in the bios thats it just like @Himommies said and why do you need 5 displays?
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309782
Thank you so much this was so quick but how exactly would i do that. I've only just built my 1st pc and still learning everything i can but as for why? Well I'd like to enjoy some anime while i edit and have my game up for if ever i need a break really n.n
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309799
It's under onboard devices the last time I tried doing that but it varies mobo by mobo
My life
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309806
Ok thanks again. So much help its 5:11am here. Ive been up all night figuring out whether to even buy them incase it didn't work but i'll just look up my mobo and how to do it when i wake up. FINALLY! Im not gonna be stuck with 2 monitors anymore considering its not the best and i dont know why this guy had it set up like this but i figured its a pretty good deal
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309845
If you can’t get it working through the motherboard port (I know mine doesn’t) you could always use your old gpu (if you have it) to run some of your other monitors
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309925
Unfortunately my mobo doesn't have 2 PCIe slots so that can't happen but what happening with yours? Does your cpu not have an iGPU?
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10309988
It does but I think my mobo just doesn’t let you use the ports if you have a gpu in. Who knows it might and I just haven’t realized.
https://linustechtips.com/topic/822953-multi-monitors/#findComment-10310005
