So, a year ago I built my rig with an i7 6700K and an MSi Z170A Gaming Pro Carbon. I was able to dial in an overclock to 4.7GHz 1.38V, it was 100% stable and I was happy with it. 6 months later, I plug something in the USB 3.1 Type A, and it literally corrupted windows, after 6 windows reinstall I can confirm that the port is the cause of the BSODs and windows corruption.
Then I bought an ASRock Z270 Extreme4 because the MSI had a broken port AND I needed more SATA ports. Plus I thought the ASRock looked better.
I tried dialing my OC in the new board, it BSODed for bad OC, I just brought it back to stock and was happy about it. 3 days ago I decided to give overclocking a try, and I got it stable again at 4.7GHz with 1.385V this time. It has been stable since (I gamed all day yesterday and it never crashed, temps were fine). Today, I was browsing youtube, suddenly all my screens go black, but sound keeps playing (dedicated GPU and dedicated sound card), comes back with a sound of USB unplugged, and now none of my USB ports are working in Windows, I reboot, I can get into the bios, both keyboard and mouse are working, try to boot, gets to the login screen, none of my USB works, nor my PS/2 keyboard. I try to reboot again, BSOD: unable to reach boot device... I reboot again, the raid controller says all my drives are fine, and I can get into the BIOS again and my USB devices work, but I can't boot anymore...
Are my problem caused by my overclocks being too hard on the board voltage wise? Or am I just bad-lucky?
Record holder for Firestrike, Firestrike Extreme and Firestrike Ultra for his hardware
Top 67 for TimeSpy and Top 26 for Timespy Extreme
Intel i7 10700 || 64GB Kingston Predator RGB || Asus H470i Strix || MSI RX 6700XT Merc X2 OC || Corsair MP600 500GB ||  WD Blue SN550 1TB || 2TB Samsung QVO || EVGA 550 GM || EK-Classic 115X aRGB CPU block - Corsair XR5 240mm RAD - Alphacool GPU Block - DarkSide 240mm external rad || Lian Li Q58 || 2x Cooler Master ARGB 120MM + 2x Noctua  Redux 1700RPM 120MM  || Terramaster D4-320 HDD enclosure w/ 1x 8TB 256mb cache 7200rpm Ironwolf & 1x 4tb WD Red 256mb cache 7200rpm
https://linustechtips.com/topic/822894-overclocking-side-effects/
bad luck, try to add more voltage on your CPU, might fix.  i had an issue with windows just not booting up (couldnt find bootloader) because i installed a different GPU :(
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Your issue is called "MSi" :P
Personal Desktop":
Luna, the temporary Desktop:
Try resetting to stock clocks and see what happens.
CPUs degrade slightly over time, so you might need to either pump a bit more voltage, or lower the clockspeed, after several years of use. however, this seems too soon for that to be an issue. maybe the board just has worse power delivery (less phases, more ripple, etc.)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
It wasn't my first board, but I don't know how I feel about them, they feel cheap and their drivers are subpar for the audio chipset, but they deliver some solid OC stability and a great customer support in Canada, plus now I have a dedicated sound card...
Also, I'm having issues with the ASRock one now... So that's why I'm starting to think I'm the problem
The MSI had 7 phases, while the ASRock has 10... the power supply is the same (EVGA 650GQ, not the best, but does a good job)
Hm...
Strange.
TBH IDK
Laptop:
22 hours ago, RadiatingLight said:
Hm...
Strange.
TBH IDK
I reset my clocks to stock, will use it for a while, then, if the crash doesn't happen, I'll start over with my overclock and see what will happen
