Voltage for 6600k
Go to solution Solved by rn8686,
11 minutes ago, Intel HD Graphics said:
i have a bad cooler but it doesent seem to go past 70 c, is that ok ?
That should be fine, it will throttle anyway before any damage could occur.
Yep.
But just don't go any higher on voltage.
1.35 is generally considered the safe limit.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/822728-voltage-for-6600k/#findComment-10307637
If your cooler can handle it, thats fine.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/822728-voltage-for-6600k/#findComment-10307642
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/822728-voltage-for-6600k/#findComment-10307695
