CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($108.89 @ OutletPC)
Motherboard: *ASRock - AB350 Pro4 ATX AM4 Motherboard  ($60.49 @ Newegg)
Memory: *Patriot - Viper Elite 8GB (2 x 4GB) DDR4-2800 Memory  ($69.99 @ Newegg)
Storage: *MyDigitalSSD - BP5e Slim 7 128GB 2.5" Solid State Drive  ($54.99 @ Amazon)
Storage: *Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.38 @ OutletPC)
Video Card: *EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($209.68 @ OutletPC)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($59.99 @ NCIX US)
Power Supply: *SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($41.89 @ Newegg)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($187.49 @ B&H)
Keyboard: Redragon - K552 Wired Gaming Keyboard  ($32.99 @ Amazon)
Mouse: Redragon - Centrophorus M601 Wired Optical Mouse  ($13.99 @ Amazon)
Other: SteelSeries QcK+ Gaming Mouse Pad (Black)
Other: Flat Ethernet cable, 50Ft Cat6 Slim RJ45 Network Cable with Cable Clips, Higher Speed than Cat5e Cat5 Computer Cable for Computer Laptop/ Desktop Switch/ MAC Laptop - White  ($17.99 @ Amazon)
Total: $902.76
Generated by PCPartPicker 2017-08-15 18:21 EDT-0400
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Total: $902.76
So do you think this will run pubg just fine?
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.79 @ SuperBiiz)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard  ($93.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($82.88 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($144.88 @ OutletPC)
Power Supply: Corsair - CX (2017) 550W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Amazon)
Keyboard: Cooler Master - Devastator II Wired Gaming Keyboard w/Optical Mouse  ($25.49 @ OutletPC)
Total: $829.38
Generated by PCPartPicker 2017-08-15 18:24 EDT-0400
i have the same pc will run on all very low then textures on high (thats the best settings for pubg) or you could play just normal everything
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
maybe 60 fps
with the shortages, you can't really get much right now :S
Full Specs
Helios EVO (Main):
Delta - Laptop
maybe 60 fps
Yes, it will run PUBG fine, but the 1060 in there only has 3GB VRAM, which will gimp the card in the future.
if possible, try to increase budget to fit in a 1060 6GB.
under normal conditions, you would've been able to fit even an RX 580 8GB in there, but nowadays, with miners and stuff, all GPU prices are sky-high.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
That's why these motherboards exist:
Full Specs
Helios EVO (Main):
Delta - Laptop
