Seems good to me, just use an AsRock or ASUS board, because MSI boards for Ryzen have a lot of issues ;)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302800
What sort of problem?
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302815
BIOS not handling overclocks as intended. I think it's fixed since it's been so long, but it's still better to pick brands that don't have this problem before: less chance for them to screw up in the future.
Desktop benching:
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302824
All sorts of issues, they fail to post, they take too long to post, they have issues with memory compatibility etc.
@tom_w141
@Princess Cadence
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302829
Just now, SkycoderOZ said:
Ok, do you have any recommendations
The AsRock B350 Pro4 is very good ;)
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302866
Just this yesterday, as you can see people complaining about MSi boards, mainly the Tomahawk are full of issues, it is not worth the small savings you get, I strongly suggest going Asus as mentioned above.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/822266-ryzen-upgrade-help-20/#findComment-10302950
