beast.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10299274
Nice. Why the unbalanced CPU/GPU? I would've gone for a 1600 and 1070/ RX Vega 56
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10299310
Well , tbh I accidentally build this. Just before ryzen launched I won this case at my local PC hardware store in a facebook contest. The front accents are orange so I thought let's build a ryzen rig.
The gpu is coming from my old system and since I only play at 1080p this gpu will do the trick. I planned to upgrade the gpu as well but prices in the Netherlands are over the top due to miners...
My other hobby besides accidentally building pc's is rallycross and I often render my Gopro footage so I thought let's go for the ryzen 7.
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10299419
solid reasoning, can't fault you for any of it.
System specs:
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10299429
Alright, makes sense. Great build though, looks nice!
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10299462
5 minutes ago, Necrodor21 said:
should be running at 3.7 but keep taking 1.6ghz clock speed
Oke. Which board you got and which ryzen? The ryzen 5 1600 and ryzen 7 1700 got some weird bug when you dial in a manual voltage.
I got a gigabyte AX370 aorus gaming 5 . After the last bios update my OC failed as soon as I dialed in a static vcore. In the bios it was showing correctly but as soon as I booted in windows my multiplier was stuck solid on 15.5x.
I contacted gigabyte tech support and they send me a beta bios that I'm still running and it works fine now.
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10302289
I contacted gigabyte tech support and the send me a beta bios that I'm still running and it works fine now.
i should contact asrock tech sup then
how you asking them?
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10302293
Well I just filled in a form on the gigabyte website and explained my problem. The day later I got a response if I wanted to try this beta bios so they send it. Dunno how asrock support works to be honest but I guess it's quite similar.
Maybe asrock got a forum as well we're they put up beta bios's to try out.
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10302303
thanks for your help
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10302307
you got minimum processor freq or something similar with minimum at processor power management?
https://linustechtips.com/topic/821947-my-ryzen-build/#findComment-10302704
