Hello Im plannig on buying the Thermaltake H15 for a budget build, however it only comes with one case fan and I was wondering if is it good ?
Or should I buy a different one or maybe add another one.
I was thinking on this combo:
Rear Fan (AF): https://pcpartpicker.com/product/XhCwrH/bitfenix-case-fan-bffscf12025kkrp
Front Fan (SP): https://pcpartpicker.com/product/cwcMnQ/bitfenix-case-fan-bffsxtr12025krp
https://linustechtips.com/topic/821323-case-fan-needed/
if it's a budget build there is no need for an extra fan. Do you have an idea of full specs? If your gaming then maybe 1 more fan would be nice. I have r5 1600x OC 3.8Ghz, Gtx 1060 6gB and only 2 case fans. Temps are fine in my Mid tower ATX Case (Corsair carbide spec-03).
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/821323-case-fan-needed/#findComment-10292845
My advice is to avoid that range of fans entirely as they are not good value, and generally not very good fans either.  If you do go with Corsair, then their ML range of fans are far better quality and value, and look much better too.  But, other better fans do still exist.  Noctua, Bequiet, Phanteks, Noiseblocker, EK, Antec, Coolink and many other companies make better fans than Corsair, but they may be more expensive or difficult to get hold of.  Some are even cheaper however.
https://linustechtips.com/topic/821323-case-fan-needed/#findComment-10293025
