hey,
I was thinking of updating my tower and due to the current value of ryzen over intel i decdied id break my trend and go for an ryzen 5 build over an i5 build here is my PC part picker list my main need for advise would be the case im looking for the smallest possible mini itx case that can fit a be quiet showrock lp and a full ATX powersupply
PCPartPicker part list: https://uk.pcpartpicker.com/list/2VTJr7
Price breakdown by merchant: https://uk.pcpartpicker.com/list/2VTJr7/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£178.95 @ Aria PC)
CPU Cooler: be quiet! - SHADOW ROCK LP 51.4 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: Gigabyte - GA-AB350N-Gaming WIFI (rev. 1.0) Mini ITX AM4 Motherboard  (£103.93 @ CCL Computers)
Memory: Corsair - ValueSelect 16GB (1 x 16GB) DDR4-2133 Memory  (£116.64 @ Aria PC)
Storage: ADATA - XPG SX8000 128GB M.2-2280 Solid State Drive  (Purchased For £0.00)
Storage: Crucial - MX300 1.1TB 2.5" Solid State Drive  (£235.51 @ Amazon UK)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Low Profile Video Card  (Purchased For £0.00)
Case: Thermaltake - Core V1 Mini ITX Tower Case  (£33.60 @ Amazon UK)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For £0.00)
Operating System: Microsoft - Windows 10 Pro Full 32/64-bit  (Purchased For £0.00)
Total: £668.63
Generated by PCPartPicker 2017-08-13 02:05 BST+0100
I lurk a lot
https://linustechtips.com/topic/821209-planning-a-ryzen-5-build/
I think your current tower only needs a new graphics card and it will be good already. Unless you do productivity work you don't need Ryzen at the moment
For a Ryzen build though:
Get 2800MHz+ RAM. Ryzen value RAM as much as you value a small case.
The official website of the CPU cooler doesn't mention compatibility with AM4 motherboards, so I assume it's not supported.
Desktop benching:
5 hours ago, Leshya said:
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (£130.74 @ Amazon UK)
Get this memory kit.
hmm that's quite a bit more than the kit I chose trying to keep it as cheap as possible
I lurk a lot
