Cinebench is a good CPU benchmarking software, and Unigine Heaven and Valley are good graphics card benchmarks.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291586
Aida64 for stressing CPU
HWMonitor/RealTemp for monitoring temperatures
CPU-Z for various system specs
GPU-Z for GPU specs and stats
3DMark for system/gaming benchmarks
Cinebench for CPU benchmarks
Unigine Valley and Heaven for gaming type benchmarks
CrystalDiskInfo and ATTO for storage benchmarks
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291587
6 minutes ago, Jonathan Lemmens said:
Also: Benchmarks are used to determine PC performance. 'Bench marks' are left by people who didn't wipe their ass properly. :D
i am not sure if you are trolling or not but benchmarks are good for determining stability and performance.
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291645
13 minutes ago, rrubberr said:
I wouldn't trust Cinebench for honest CPU benchmarking, the amount it relies on core count (or hyperthreading being enabled) shows that it isn't an accurate tool.
4 minutes ago, rrubberr said:
No, I mean cinebench, thanks.
It doesn't rely on core count or hyperthreading.  It simply scales almost perfectly with them as it should.
Cinebench is a great benchmark for determining CPU performance under perfect scaling conditions.
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291646
I thought stress tests are to determine stability, benchmarks are to determine performance? Most programs mentioned here do both
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291648
Some people use benchmarks to test their stability.  I personally do not do this, but if it as stable as they need it to be, that all that really matters.
If all someone does throughout a day is open Microsoft Word and Google Chrome, Cinebench R15 one time might be good enough for them to call they system stable.  xD
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291656
Just as long as they don't call it "fully stable," because that leads to arguments on whether 'fully' is a prefix or not.
They, along side the new Superposition, also make for great screen savers or looping backgrounds in videos.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/821204-bench-marks/#findComment-10291784
If you want to be completely certain your build is "stable", use prime95 and leave it running for a few hours. It's also good for testing CPU overclocks.
Daily Driver:
Gaming PC:
https://linustechtips.com/topic/821204-bench-marks/#findComment-10293643
