Looking for a specific fan splitter
Solved by W-L,
1 minute ago, Tech22 said:I am looking for a fan hub that connects to a board with PWM and has 4/5 PWM Headers on it. I would also like it to have supplementary power (like molex or sata) to make sure I can run the fans at 100% (if I need to :D). I would prefer a hard mounted PCB. Thank you!
Also, not sure where something like this goes.
Something like this?
http://www.swiftech.com/8-WayPWMsplitter-sata.aspx
-Moved to Aircooling-
