Help with excel
Go to solution Solved by vanished,
11 minutes ago, AntonDVries said:
Just change the text colour
Sorry for the slow reply, I got caught up on other things.
Select the cell you want to change colour (G5) and go Conditional Formatting  >  New Rule...
then select Use formula to determine which cells to format
click in the text entry field and then click your cell to detect (F5) then finish off =""
Pick the formatting you want with Format... (make it white text).  That way if F5 is empty, G5 will go white, otherwise it will be visible.
Do you want it to just appear blank (change text colour) or actually become empty?  Because how you would do that are two different ways (both are pretty easy tho).
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10282689
Thats done with conditional formatting. I haven't used that into extend where I could assist you without reading online guides on how to.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10282728
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10282753
You. Are. The boss. Thank you so much
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10282837
One more thing, how do I copy paste it to another row, or do I have to manually do that (row for row a new condition)?
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10282853
Ah, yes, that is a bit more troublesome.
Select the cell (G5) and go back into editing (Conditional Formatting  >    Manage Rules...)
Click Edit Rule...
In the textbox, modify the line from =$G$5="" to just =$G5="", removing the $ sign between the G and the 5.
Now, click OK twice and notice the green square in the bottom left of the selected cell (G5).  Grab that and pull it down as far as you want, and it should extend the formatting all the way so that G8 will change based on F8, etc.
https://linustechtips.com/topic/820447-help-with-excel/#findComment-10285121
