40 minutes ago, Dreaper said:
MpCmdRun using all cpu usage and cant fix it cant end the process either
Hi @Dreaper
you can not end it since the process is probably owned by "System". Try to temporarily disable Microsoft Security Essentials as this process is probably used for this program.
Edit: if the sugesstion above does make any different. A workaround for your issue might be, to add a exclusion in windows defender / security essentials for mpcmdrun.exe. (Keep in mind that this might stop secutiy essentials from scanning your computer constanly potential lowering system protection)
Ps: see picture in spoiler to find filelocation of any process
