Port Forwarding Issues - HELP
Go to solution Solved by Lurick,
6 minutes ago, rogvid700 said:
-snip-
Well unfortunately that confirms what I thought.
Your carrier is using what's known as CGN (Carrier Grade NAT) and is essentially a double NAT where you get natted to an address and then that address gets natted again. It's supposed to prevent IPv4 address depletion but really is just a way for an ISP to be lazy and not migrate to IPv6. In your case, it looks like your ISP hasn't even started enabling IPv6. There are some workarounds but they aren't free (last one is but requires a lot of trust :) )
1) Find a VPN provider and setup a VPN tunnel between your server and them. Your friends would connect to the VPN provider IP address and the traffic would be funneled back to the server.
2) Find a VPS provider and setup OpenVPN and tunnel between it and you.
3) Setup a local VPN, have your friends login to the VPN locally, and connect to the server using the local 192.168.1.2 address
I'm having an issue getting the port Minecraft uses open to allow other players to connect to my server. I've been doing this for years and have never encountered a problem so aggravating as this one. Let me break down what the issue is.
I just recently moved into a new apartment and got a new router and new ISP so things have been a little different than usual for me when it comes to port forwarding but nonetheless I got most of what I can do accomplished already.
  • I have opened the port and forwarded it on my router's gateway to the correct internal IP of my PC that I'm running the Minecraft server on:
  • I have completely disabled my windows firewall as well as added an incoming rule that allows connections to the 25565 port on both TCP/UDP protocols. Still to no avail. So I'm fairly certain windows firewall isn't the issue.
  • This is the second router I have tried this on and still other players can't connect using my external IP so I know it's not a router-specific issue.
  • My router is connected to a DirecTV adapter that gets the internet signal from a coaxial cable from the wall, just thought I'd point that out as previously at my last apartment when none of this was an issue, I didn't have that adapter.
  • My Minecraft SERVER-IP: is blank in the properties.
  • I have tried a different Minecraft server even, though probably not related just in case
  • I have tried connecting to my Minecraft server locally using my local internal IP, and it works fine, I am able to connect without a problem
And I'm using PFPortChecker to determine if the port is open or not:
Any and all suggestions would be fantastic. I'm typically one of those people who only use asking on forums or calling a support line as a last resort. So when I tell you I've tried A LOT of things to fix this, believe me I have haha. Thanks!
https://linustechtips.com/topic/818880-port-forwarding-issues-help/
ISPs sometimes block ranges of ports from inbound traffic.
Try netstat -a to see if that port is even being listened on.  If it is, your ISP is blocking.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
After running it, the only result that mentions the port: "0.0.0.0:25565" State: Listening
So then does that confirm they are blocking it for certain?
Unsure what that result means.
Can you try having someone connect to a different port?  Forward port 9995 or something to port 25565 and then see if that port works from the internet?
Alternantively, contact your ISP and ask them for a list of ports they block inbound traffic on.
Can you please post the first half of your external IP according to ipchicken.com, and also the first half of the WAN IP that your router reports? And while you are collecting those, verify whether the two IPs match 100%.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
ipchicken: 40.136.X.X
(WAN IP wasn't listed anywhere specifically, but I do have my IPv4 which is different from what ipchicken posts)
IPv4: 10.1.X.X
5 minutes ago, rogvid700 said:
Anyone have any ideas? I tried contacting my ISP for information about blocked ports and got no response....
You're external IP is a public address (40.136.x.x) but you say your internal address is a 10.1.x.x address (you can post the full 10.x.x.x address by the way, it's a private address so nobody can do anything with it). You're port forwarding to a server on the 192.168.1.x network, specifically 192.168.1.2.
Where did 192.168.1.2 come from?
If you go to Start > Run > Type in CMD > then type ipconfig
What does it return? 192.168.1.something or 10.1.something.something?
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
192.168.1.2 is my computer's internal IP address that the server would be running on. The 10.1.X.X number is the number I found when looking for a WAN IP on my router's homepage. I'm not sure if it is even relevant, but I figured I'd post it since there was no mention specifically of a WAN IP. I used ipconfig initially to find my internal IP. It's just so strange that despite having it seemingly port forwarded correctly that my public address just doesn't work.
Hmmm, just to make sure, to access your router you go to 192.168.1.something?
But under settings it lists the WAN IP it received as a 10.x.x.x address?
I think I know the issue but want to make sure the above is correct :)
Prior Build Log/PC:
My router's gateway is 192.168.1.1 not to be confused with my computer's internal IP 192.168.1.2. I use the first number to access my router yes. Here's a couple screenshots of what my router tells me:
-snip-
Prior Build Log/PC:
Ughhhh! I knew something like this would end up being the case. Thanks again for your help I really appreciate it!
go into firewall add that ipaddress and port
then do same for port forward except its
inbound from 0.0.0.0:25656 to 192.yourip:25656
outbound from yourip to 0.0.0.0:25656
your ip port not big deal choose any number 1025 to 65535
but 0.0.0.0 port number does matter... it must be port you desire forwarded
add what i said to the firewall as your minecraft already set(although 192.168.1.0 set for all ip 192.168.1. 1to255) instead just single ip
