What do you guys think the minimum PSU (based on system of course) would be suitable for power hungry cards, like Vega?
I plan to upgrade to Vega 64 from my R9 380, and I currently run a Corsair CX750M PSU.
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/818820-vega-power-usage/
What is the rest of your system? And what vega 64 will you get?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263596
I run a Core i5-3570 (non k) at 4ghz with an Arctic Liquid Freezer 120 on it.
The other things worth noting are:
1x SSD
3x Sata HDDs (7200RPM)
Asus Xonar Essense ST PCI version\
Elgato HD60Pro PCI-E
I ran Power Supply Calculator (Outervision), and they suggest a 619W, so I think I am fine.
I will probably get the limited one.
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263623
1x SSD
Which limited one?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263627
Which limited one?
Sorry lol
The air one.
The liquid one looks to only be in the Radeon Packs, and I know for a fact I would have to get a bigger PSU for that.
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263630
Sorry lol
The air one.
No you wouldnt.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263636
Sorry lol
The air one.
Then you probably will be fine, as long as you don't go crazy on overclocking it.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263637
I'm pretty comfortable with my Seasonic G750 being able to handle Vega 64 no problem and I have a pretty aggressive overclock. I should think a non K 3570 based system will be fine with a 750.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263642
I will probably leave it stock.
I am only gaming at 2560x1080 for now, but I want to be good for a while.
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263647
1 minute ago, Jrock said:
No you wouldnt.
Well that's good to know!
The liquid one looks to be a beast power consumption wise.
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263652
You'll be fine with your existing 750W PSU.
The power requirements account for the ENTIRE system -- and the "650W or 750W" requirements on the back over-compensates.
Some people with have THIS kind of janky "650W" PSU....https://www.newegg.com/Product/Product.aspx?Item=9SIA93846S3911
And not like these....https://www.newegg.com/Product/Product.aspx?Item=N82E16817139200&ignorebbr=1
The Sapphire NITRO R9 Fury recommends a 750W for a single card....yet I have TWO powered by a 850W.
The last time I checked, the entire system pulls under 750W from the wall socket (PSU is plugged into a power meter).
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263663
750watt psu is enough to run dual 1080ti's in SLI.
especially with only an i5 in your system, power consumption will probably be at 600 watts max load.
PCpartpicker has a good explanation of how PSU calculators work.
How does a mobo draw up to 70 watts? For GPU power. But that 70 watts is also included in the GPU power. And RAM. It goes on and on.
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263671
Sounds good to me!
Desktop:
Corsair RM850X
Elgato HD60 Pro
Logitech G903 Mouse
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
https://linustechtips.com/topic/818820-vega-power-usage/#findComment-10263720
