So i have ryzen 5 1400, zotac gtx 1050 mini 4gb, ram 8gigs single channel 2133mhz, seagte baracuda 1t hdd, win 10 home ,mb asrock 320m, psu cheftech 500w
And yes i bearly have 100fps in cs go on low settings. Its worst than my i 5 4460 build whit allmost same spec except cpu and gpu is rx 460 and on i5 build i get 300+ fps in cs go.
My questions is why its slow?
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/818583-ryzen-system-slow/
2 minutes ago, RaptorCandy said:
Have you reinstalled the GPU drivers by using DDU (Display Driver Uninstaller)?
And make sure the DVI/HDMI cable is connected to the GPU and not the motherboard.
r5 CPUs don't have integrated graphics, so there wouldn't be any video output if the HDMI/DVI cable were connected to the motherboard.
@Bayron what's the exact model of RAM that you're using?
Ryzen CPUs benefit immensely from higher frequency RAM. If your memory can support it, I'd suggest updating the motherboard bios and activating the highest A-XMP profile available
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261280
Im not that dumb and the drivers isnt the problem
Model i cant remeber right now but it was samsung somesome sort. i have read ryzen likes more mhz ram but realy do i need to upgrade? And yes bios maybe is outdated
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261295
I never said anything about an upgrade. Just asked about RAM model so I'd get an idea of how high the frequency could go on it. Trying the A-XMP angle might give some results
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261302
dont think my mb supports that :D its 320 platform and ram model is Samsung 8GB 2133Mhz 15CL DDR4 M378A1K43BB1-CPB BULK
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261320
I don't think a RAM change will triple your performance. Something else is going on here...
From what I gather lots of gamers have issues with AMD CPU's on CS:GO. At least on the older AMD Chips.
Also, being an _old_ game its probably optimized for intel's supplementary instruction sets like SSE2 etc. Even though Ryzen supports those old instruction sets, the games might not be recognizing them on an AMD CPU.
Firstly however, I would compare a modern game (last year or so) between your i5 and ryzen system and see the difference.
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261343
A lot of things to add for one CS;GO and ryzen don't go together as well as a I3 or better CPU. Second you only have one ram dimm meaning the Infinity fabric is also getting a HUGE bottleneck.
That is the issue.
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261396
That is the issue.
so it means i have to change ram?
and ryzen cant run on single channel?
so ryzen is bad than?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10261591
Infinity fabric needs dual channel high bandwidth memory. Also Intel is still a better choice for single threaded games like CS:GO. Just about the only thing the I5 is better at.
Technically running at 2133 even in dual channel is a massive bottleneck but having only one dimm meaning half the bandwidth again that basically makes ryzen perform like total crap. I bet even normal scores are down like in Cinebench and geekbench and whatever else.
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10262747
7 hours ago, Bayron said:
So it means I have to change RAM?
And Ryzen can't run with single-channel?
So Ryzen is bad, then?
-No, it means you'd be best served getting an additional stick.
-You're running Ryzen with single-channel RAM.
-The fact that the rest of the system can affect Ryzen's performance does not make Ryzen bad.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10262922
Yeah, it's not that Ryzen is bad, but there's a few caveats with the new platform, so cutting corners on the mobo and RAM hurts.  CS:GO and other legacy games will favor single core performance.  Dual channel RAM will help out but I also would've said to stretch for the B350 for OCing.
https://linustechtips.com/topic/818583-ryzen-system-slow/#findComment-10263013
