Ryzen 3 and dedicated gpu or intel solution?
Go to solution Solved by Terryv,
Pentium (new pentium) + iGPU from said pentium with an SSD will make it look like the fastest thing in the world from their perspective.
Hello.
I wanted to part out a system for my grand parents who complain their old computer is slow. it runs a Pentium 3 and Windows XP. I was wondering what the best way to go about building this budget non-gaming oriented system. should I go i3 with integrated GPU or Ryzen 3 with a cheap dedicated GPU? or something else entirely?
Thanks in advance.
https://linustechtips.com/topic/818476-ryzen-3-and-dedicated-gpu-or-intel-solution/
Anything. Hell, A Core 2 Duo machine with integrated graphics would probably blow them away. I recently scored a complete q6600 dell for 8$. Just see what you can find! If you must build with new parts or can't find anything, get a pentium.
i7 2600k @ 5GHz 1.49v - EVGA GTX 1070 ACX 3.0 - 16GB DDR3 2000MHz Corsair Vengence
Asus p8z77-v lk - 480GB Samsung 870 EVO w/ W10 LTSC - 2x1TB HDD storage - 240GB SATA SSD w/ W7 - EVGA 650w 80+G G2
3x 1080p 60hz Viewsonic LCDs, 1 glorious Dell CRT running at anywhere from 60hz to 120hz
Model M w/ Soarer's adapter - Logitch g502 - Audio-Techinca M20X - Cambridge SoundWorks speakers w/ woofer
Without knowing what your grandparents' use case is, this is about all they'd need for a basic home workstation for surfing the web, emailing their grandkids and watching cat videos. If the budget allows, you could swap out the HDD for an SSD. Maybe more RAM. Unless your grandparents are hardcore gamers, this will probably have them set for 5-6 years to come.
CPU: Intel - Pentium G4400 3.3GHz Dual-Core Processor  ($52.39 @ OutletPC)
Motherboard: Gigabyte - GA-H110M-M.2 Micro ATX LGA1151 Motherboard  ($46.99 @ Amazon)
Memory: Corsair - 4GB (1 x 4GB) DDR4-2133 Memory  ($36.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($46.88 @ OutletPC)
Case: DIYPC - MA01-G MicroATX Mini Tower Case  ($21.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($23.98 @ Newegg)
Optical Drive: Lite-On - iHAS124-14 DVD/CD Writer  ($15.89 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($30.00)
Total: $275.10
Generated by PCPartPicker 2017-08-06 20:59 EDT-0400
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
Total: $275.10
This is a solid parts list, I second this.
not that my opinion means much
1 hour ago, Evil Ninja said:
I'd probably use a 240GB SSD though.
Remember, the SSD doesn't need to be massively fast. I've got an extremely old 80GB SATA II SSD that paired with a core2duo and windows 7, it still boots fast enough to skip the second half of the boot logo animation
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
  • 2 weeks later...
