Hello, me and a family memeber are trading PCs and i was wondering if there would be any errors between my c2d lenovo and a i3 inspiron
My goal is to transfer HHDs
Bettween the pcs
And transfer the 730 to the i3
Will it work
Best of myself(1000th post)
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Cooler Master masterbox lite 3.1
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Dell precision t3400 motherboard
https://linustechtips.com/topic/818346-will-a-hdd-and-gpu-trade-work/
I read something about the driver chipsets and if you swap hdds the pcs wont boot
Is this true?
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
27 minutes ago, Septimus said:
Windows keys are tied to the motherboard, so you may have to re-activate your Windows keys through Microsoft if you swap the HDDs.
Have you ever swaped HHDs before
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
Most likely no. It's hit or miss. I've gone from one q6600 machine to another and it didn't work, I've also transfered a OS from a Athlon 64 to a core 2 duo and it worked fine.
So don't count on it. There are also ways to "fix" a OS to work on different hardware, but it also has mixed results. Fresh OSes are the way to go.
i7 2600k @ 5GHz 1.49v - EVGA GTX 1070 ACX 3.0 - 16GB DDR3 2000MHz Corsair Vengence
Asus p8z77-v lk - 480GB Samsung 870 EVO w/ W10 LTSC - 2x1TB HDD storage - 240GB SATA SSD w/ W7 - EVGA 650w 80+G G2
3x 1080p 60hz Viewsonic LCDs, 1 glorious Dell CRT running at anywhere from 60hz to 120hz
Model M w/ Soarer's adapter - Logitch g502 - Audio-Techinca M20X - Cambridge SoundWorks speakers w/ woofer
Ill just buy a usb flash drive and transfer files
Vista
Core i5-8400
8GB DDR4
GTX 1050ti
1TB 7200RPM HDD
MSI H310M PRO-VD
EVGA 450BT
Arctic Cat
Core 2 quad q8200
8GB DDR2 ECC
GTX 550ti
1TB 7200RPM HDD
