Hello everyone, I hope you all are having a swell weekend so far!
I wanted to ask you guys about the low fps I am experiencing in games such as Borderlands 2, Overwatch, H1Z1, etc,.
When I am playing these games I constantly have 100% CPU usage but my GPU never surpasses 60%. When I am playing I always make sure that most of my processes are turned off. I used to get around 75-90 fps on Overwatch a couple of months ago but now it's down to 35-50 fps.
Is it something wrong with my CPU being dual core? Is it bottlenecking? Do I just need to clean my PC?
CPU: Intel Pentium G3258 @4.2 GHz
GPU: MSI GTX 970 Gaming
Motherboard: Gigabyte Z97MX- GAMING 5 LGA 1150
RAM: 8 GB
PSU: Corsair CX600
Monitor: BenQ 24-Inch Gaming Monitor - LED 1080p HD Monitor - 1ms- RL2455HM)
Storage: Samsung SSD 850 EVO 500GB
Thank you for your time!!! :)
https://linustechtips.com/topic/818118-need-some-advice-high-cpu-usage/
RAM: 8 GB
PSU: Corsair CX600
Your CPU sucks for the kind of gaming your doing, it's bottlenecked. get a 4790k
lttstore.com
No lol. That is the power supply I have currently. I wanted to ask if that one is fine.
English man, the cx600 you own is horrible. Upgrade to a EVGA b2 power supply probably 650watts will do the job.
lttstore.com
Hi how long have you had your cpu if you have owned for a long ammount of time sometmes it can wear down i dont know the specifics on your cpu as i am a amd user my self but if your processor is unlocked maybe try uping the voltage a bit my old fx 8120 had the same problem raised voltage a bit like 20% better fps in cpu demanding games like gta
I had it for 2 years.
You could build a amd build that would crush that for like 300 using the am3+ socket and you would be able to play gta v at high settings at 45 fps get a used fx 8350 and a Radeon r7 260x by gigabyte 2 gb gddr5 oc eddtion and for love of god pick a good psu this time
No offense but:
1.) Did you hear about am4 and ryzen which you can get for cheaper with more performance? There is absolutely no reason to recommend am3 stuff anymore
2.) Cpus don't decrease in performance over time, its not an engine
EDIT:
3.) Raisimg voltage alone doesn't do anything but produce more heat. If you want to get more performance you have to increase clock speeds, and if a certain cpu is at an overclocked speed not stable, you slowly increase voltage.
If you want to help people out, know what you are talking about and do not spread misinformation and/or recommend totally outdated stuff
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
I was not ryzen is two expensive for the 300 dollar price range i set the fx 8350 is a octa core processor and would perform better then a ryzen 3 belive me i love ryzen i have a ryzen 7 1700x
I love it and am planing on getting a threadripper but a ryzen 3 is a quad core and cant stand up to its 100+ price tag a fx 8350 goes for like 60 to 70 usd
I don't understand what is wrong with the cx600, I have not experienced any problems with the power supply and I had it for over 3 years and nothing has happened.
CX600 has bad ripple, bad voltage regulation, and shotty components
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
