Do you already have a PSU in the server? Do you have some Molex that are free?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/817556-power-supply/#findComment-10251490
unplug the 24 pin connector and grab a paper clip. make it so that the paper clip has two ends and plug it into the green slot and the black one right next to it:
500x1000px-LL-ad9e1227_atx-connector-20-
And switch the power supply on
Current Build
Successful Builds
https://linustechtips.com/topic/817556-power-supply/#findComment-10251501
Would it work to run it like that. for server cabnet Fans With Molex adapters   and run like that 24/7
https://linustechtips.com/topic/817556-power-supply/#findComment-10251508
it should, I ran a water pump that uses molex and an old psu like this. Never tested it for 7 days 24 hours.
Current Build
Successful Builds
https://linustechtips.com/topic/817556-power-supply/#findComment-10251514
-merged & moved to PSU section-
https://linustechtips.com/topic/817556-power-supply/#findComment-10251761
3 hours ago, Austinkastner said:
How can I power up an power supply Without motherboard.  I just want to run Fans in server cabnet
Depending on the Power Supply, you can or can not do it.
Some Power Supplys have a no load protection and won't turn on if a minimal load is not met.
Best/Cheapest Thing to do would be to put a USB connector  on the fan as most fans will run with 5V...
For testing purpose that should be more than enough.
What/how many fans are we talking about? What do you really want to do??
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/817556-power-supply/#findComment-10252079
