I will be buying aios and don't really like the included fans, is there other esthetic fans that perform some what as good? (esthetics = RGB (Aura sync?)
AIOs- CPU: H100i corsair
          GPU: 1080Ti Hybrid EVGA
Sorry for somewhat wasting your time, I have no idea what I'm doing when it comes to fans.
https://linustechtips.com/topic/817175-fans-for-aios/
12 minutes ago, Damascus said:
I have the Z270i ROG Strix
and there is only one aura sync fan connector, are there even such things as aura fan splitters?
https://linustechtips.com/topic/817175-fans-for-aios/#findComment-10247527
OK,  so the way it works is you have one 4 pin or 3 pin fan cable and one 4 pin 5050 rgb cable.  You need one of these for the rgb and a regular fan splitter for the fans
https://www.amazon.com/gp/aw/d/B072K21JVF/ref=mp_s_a_1_12?ie=UTF8&qid=1501816864&sr=8-12&pi=AC_SX236_SY340_FMwebp_QL65&keywords=5050+splitter
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/817175-fans-for-aios/#findComment-10247546
thanks, but does it take away from the power delivery to the fan?
https://linustechtips.com/topic/817175-fans-for-aios/#findComment-10247558
