ADDing fans to my tower ACER g3-605 help...
Solved by 1StLawofMotion,
On 3/8/2017 at 5:57 PM, mok said:that case has terrible airflow
it only has spot for a 80mm/92mm fan on the rear,
and the single 120mm that is on the power supply
i would recommend spending $30 and just getting a new case
Yeah.. I'm looking into that.. but for now I just need a new fan I ordered a 92mm Nactua fan. It will have to do for now.. any recumendations for a case I should buy?
