Are you wiring the cable over the mobo or under it? you should be able to reach it over it. If not, then you probably need this:
https://www.amazon.com/StarTech-com-8-Inch-8-Pin-Extension-EPS8EXT/dp/B000M802RG
Current Build
Successful Builds
https://linustechtips.com/topic/816613-help-with-mobo/#findComment-10241149
19 hours ago, motapinto said:
It has 8 pins. What should i do?
What case and PSU? With normal ATX PSU and normal ATX case it will go over board just fine. Most of the time even under mobo or behind mobo.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/816613-help-with-mobo/#findComment-10245459
