Hello guys..
I have been very disapointed lately with my computer performance while playing..
My specs:
My CPU: i5 4690k @ 4.2 ghz
My GPU: GTX970
SSD: Crucial MX100
Ram: 8 gb 1333mhz
Monitor: Benq xl2411z @ 144hz
Temperatures:
More than fine..
CPU: 58º - Ingame / 30º - Iddle
GPU: 55º Ingame / 28º - Iddle
The problem:
So while playing my game doesnt seem to be smooth like it used to look..it does like stutter and  gives me the king of feeling of the image dragging..the fps goes from 250/300 to 180 and the game itself seems like its broke..sometimes more than another but my experience isnt good at all..
I have done everything I could find on the internet..nvidia settings, snd_ fix, changing resolutions etc etc..all I could find I tested..I dont know how can I possibly fix this..I am really tired of not finding a solution..it seems to be the game itself..the setup seems to be fine..
Any help is really really apreciated..thanks guys :(
| Case: Cooler Master Elite 371 | Cpu: i5 4690K @ 4.20 GHz | Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z97 Gaming 3 |
 | Gpu: Gigabyte G1 Gaming GTX 970 4GB GDDR5 | SSD: Crucial MX100 256 GB | HDD: Samsung 128GB Ram: Kingston 8GB DDR3 1333MHz |
| Screen: Benq XL2411Z | Mouse: Logitech G 403 | Mousepad: SteelSeries QcK+ NiP Edition | Keyboard: Steelseries 6GV2 | Headset: Kingston Hyper X Cloud |
https://linustechtips.com/topic/816596-fpsstutter-problems-on-csgo/
DDU in safe mode and reinstall nVidia drivers fresh new.
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
This is an important first step for troubleshooting such issues.
Personal Desktop":
Luna, the temporary Desktop:
I dont really think this is the issue unfortunelly :| I have tested windows 7, windows 10... and the problem is still there
is the game installed on the ssd or the hdd?
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
on the ssd itself
1 minute ago, alvez said:
on the ssd itself
It's stretch, but could it be your cpu isn't as stable at 4.2 as it used to be? Try it out stock, and see if it still does that.
I experienced issues like this using AMD FX-8350. Pretty bad cpu.
just done it and it seems like the same honestly.. :(
If you crouch and walk around corners, while looking at the corner of a wall (close to you),  does the game chop and run unevenly?
In example Dust 2, CT to Long corner.
Yes, corners, edges in general.. Walls.. Seems choppy yeah!
