Power Supply Watts for Overclocking
Welll, OC Ryzen doesn't make a lot of sense...
Out of the 1700 you may get something like 3,6 or 3,8GHz. 4GHz is highly unlikely.
So it's better to optimize the RAM sub Timings (new thing for Ryzen). And spend money on ridiculously fast memory - that's very important...
As for the Graphics card:
nVidia said that at 'full burst' the GPU will die after only a year or so...
But at least here you can get a bit more out than the CPU.
But honestly: OC is rarely worth it these days...
Not nearly as valuable as in the olden days.
On the CPUs it works, you can't really do shit because they are close to the maximum. And on the CPU it's worth with trying it doesn't work...
As for the CPU:
500W is plenty. You really need to push your hardware and do 'Sledgehammer overclocking' wich will make your components die rather quickly to be able to go in that direction...
