A couple things:
Dont skimp on the thermal paste. I use Arctic silver 5.
You can make any CPU cooler a red one if you swap the fans for red ones.
Id consider a case with better airflow if you are going to use the parts you are. (G21 tg for example)
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10238115
Why would you need a 4 TB HDD lol? Are you planning on streaming, etc>?
Current System Specs:
CPU: Intel I5-7660K; CPU Cooler: Coolermaster Hyper 212X; Thermal Paste: IC Diamond 7 Carat; Motherboard: MSI Z270 Gaming Pro Carbon;
RAM: Kingston HyperX Fury Black 16GB (2 x 8gb) DDR4 - 2400; SSD Storage: 1TB Samsung 850 EVO; Storage: 2TB Seagate Barracuda 7200rpm;
GPU: Gigabyte Geforce GTX 1070 8gb G1 Gaming; Case: NZXT Phantom 530 Black; PSU: EVGA Supernova G2 650W 80+ Gold, OS: Windows 10 Home
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10238976
17 hours ago, Crossbred said:
A couple things:
What case would you recommend? Inwin 303? H440? R460x rgb?
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10242607
Personally I would rank them:
1) R460X
2) Inwin 303
3) H440
So probably the R460X if it falls within budget.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10243382
All of those have closed front panels. I'd go for a thermaltake case with a mesh front, as they have a lot of those, or maybe a cougar panzer.
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10243406
Im mainly trying to find a red and black one with tempered glass. As i want my build to look very clean.  @Lurick
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10247332
8 hours ago, xXBlackIceXx said:
Does the r460 have an m.2 nvme slot?
That would depend on the motherboard, not the case :P
I tried looking at the PCPP list and it says "Not found"
Prior Build Log/PC:
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10248962
The only red and black tempered glass cases I know of are the s340 elite and the 400s tg.
https://linustechtips.com/topic/816251-first-build-tips/#findComment-10248976
