My next door neighbour has given me a bunch of old tech stuff including an old Epson scanner.
My question is:
Would I be able to use the piece of flat glass in the scanner as a side panel window for my case?
(I would normally buy a new side panel with a window but I can't find the case model online from the only sticker on it)
SPECS:
AMD Ryzen 1800x @4Ghz
32GB DDR4 G.Skill Trident-Z RGB 3200Mhz
ASUS ROG STRIX B350-F Gaming motherboard
RX 5700 XT
750W Corsair PSU
Fractal Design Meshify C
250gb WD Black NVMe SSD
Peripherals:
Asus VG24V 144hz 1080p
Logitech MX Master
Corsair K70 Mk2
Stream Deck
GoXLR Mini
Logitech Z330, Corsair Virtuoso
https://linustechtips.com/topic/816055-case-side-panel-mod/
It would be very cool and near and @W-L is the modding god here
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/816055-case-side-panel-mod/#findComment-10235213
It'd be easier to go to Lowes to buy glass.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/816055-case-side-panel-mod/#findComment-10235253
He couldn't mod his way out of an open door.
pls, no ban.
https://linustechtips.com/topic/816055-case-side-panel-mod/#findComment-10235255
My question is:
Yeah you can use the glass from a scanner note it's just regular window glass usually and not tempered so just becareful when handling and moving once on the panel cause it breaks into large shards.
pls, no ban.
Let me just get my sledgehammer, one door coming right up!
https://linustechtips.com/topic/816055-case-side-panel-mod/#findComment-10235547
