I am trying to build a computer that will allow me to play games in 3840x1440 (21:9) at 100 fps, but also allow me to easily edit 4k video as well. I am trying to keep this part of my parts list within a budget around 3,600 USD (I will show my full parts list at request. It includes periphrals, etc.) The build will include some extreme liquid cooling (Dual 480mm radiators), which I am hoping will allow me to overclock my CPU & GPU without making too much noise.
CPU: Ryzen 1700 ($290 @ Amazon)
Motherboard: Gigabyte K7 X370 ($210 @ Newegg)
RAM: Corsair LPX 32GB 3000mhz ($266 @ Amazon)
DAC: DEAFidelity Elfidelity ($140 @ Amazon) (Using it to power Beyerdynamic 990 250 ohm pro)
Case: Phanteks Enthoo Primo ($230 @ Amazon)
Graphics Card: 1080 ti Founders Edition ($~700 @ ???) (Haven't been able to find any. I will be adding a second one in the future for an SLI config)
PSU: EVGA G3 1000 Watt ($201 @ Amazon)
HDD: 4TB WD Gold ($185 @ Amazon) (Picked this over WD black because it comes with a warranty)
SSD: WD Blue 500GB ($150 @ Amazon)
Fans: Phanteks PH-F140XP_BK ($18 x 12 units = $216 @ Amazon)
OS: Windows 10 Home USB ($110 @ Amazon) (I might decide to buy a Windows 10 Pro Key from kinguin to save money, I'm not sure)
Thermal Paste: Noctua NT-H1 ($6 @ Amazon)
Monitor: AOC Agon AG352UCG ($900 @ Amazon)
Total: 3,604
https://linustechtips.com/topic/815738-versatile-pc-build-advice/
Welcome to the forum!
Use PCPartPicker, it'll make your builds easier to follow, brings all the cheapest pricing together, and is what's most widely used. Off the bat I see a huge 1000w PSU. Not really much point to getting that, unless it runs fanless at under 50% load and you're really going for quiet.
If you want to go cheap, just download Windows from Microsoft. You can't change the desktop and there's a watermark, but at least you're not supporting less-than-legitimate sellers. If you like Windows, and expect updates, support them with your dollars.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Well first off, I am using a 1000 Watt PSU because I have heard they are most efficient at around 50% load, but also, because my parts will most likely require around 800 or more watts of power, so, using a 1000 watt PSU gives me quite a few advantages.
Second of all, I have bought MANY copies of windows in the past, and I want to be able to save money by buying keys elsewhere. Paul's Hardware was able to use a key from kinguin and it seemed to work fine for him.
