So I recently built my first high end PC and I am trying to of my ryzen 1800x but when i oc it when I run cinebench or something it turns off because of overheating but I have a Kraken x62 and 5 fans 4 on the road and 1 in the back.
Atleast I think overheating is the issue because monitoring it it jumps up to 97c when 100% then shuts off
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/
reseat the Kraken and try again
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231816
I have and I changed the stock thermal paste I don't understand because running a stress test now and it is on 74c but cinebench gets it to 95c
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231821
Hm, are you sure the pump is actually working and it isn't DOA?
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231827
How would I check? And it isn't much but when I try to move the actual cooler it moves bit i have to apply.some pressure
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231832
It's more of a touch and feel (and hear) situation when trying to figure out if the pump works. If you touch it and feel it spinning, it might be spinning. Also, in some AIOs you can kinda "feel" the water flowing through the tubes.
I'm not very familiar with the x62, so I couldn't tell you exactly how to check
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231838
Cant you hear the pumps working?
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231848
Pump is definitely working. Could it be I had too many volts going to the CPU? Because I turned them down just a little bit and I am going near the same temps but no shut off.
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231864
What voltage were you running?
Builds:
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231868
Nevermind that I just ran cinebench again and it turned off. Could it be RAM I heard ryzen doesnt like 4 sticks of ram. SHould I try taking it out and then try?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231875
I still want to know the voltage. You can definitely try removing two RAM sticks, could help but it won't help the temperature
Builds:
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231884
Was 1.35, I think.
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10231887
52 minutes ago, Zolfe said:
Was 1.35, I think.
That should be just fine. What overclock were you pushing? At that voltage I wouldn't expect 4GHz to be fine to be honest
Builds:
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10232040
3.7 I had a stable 3.9 yesterday but went to push to 4.0 and it wasnt stable so went back down to 3.9 and then just shut off when I did cinebench same with 3.8 and 3.7. Ill probably try and reseat the cooler again I guess
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/815737-overclocking-issue/#findComment-10232209
