I just installed my new gtx780 lightning in my rig and when i tried to start it, and the post LED didn't turn off on the GPU. I would not post. I alredy uninstalled all drivers. I tried it with my old 560ti and it worked perfectly.
P8P67 Pro B3.0
Old:2x gtx560ti SLI
i7 2600k
2*8 kingston beast 2400mhz
Fractal design newton r2 1000w
https://linustechtips.com/topic/81488-780-lightning-wont-post/
Probably DOA? can you try in another system?
CPU:
Intel Core i5 2500k - Motherboard: Asus maximus iv gene-z - RAM: 2x Corsair Vengeance Blue 4GB DDR3-1600 CL9 - GPU: ASUS GTX 770 DirectCU II
Case: Coolermaster Centurion 5 II - Storage: Crucial M4 128GB, Seagate barracuda 3TB PSU: XFX 650W XXX Edition Modular PSU - Keyboard: Ducky Shine 2 Pro
Mouse: Razer Deathadder 2013 - Sound: Razer Characias
https://linustechtips.com/topic/81488-780-lightning-wont-post/#findComment-1115965
Could be DOA? Check if you put the correct 8pin connectors into the card.
Check back with the manufacturer.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/81488-780-lightning-wont-post/#findComment-1115972
Could be dead.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/81488-780-lightning-wont-post/#findComment-1116006
