So I have an RX480 Gaming X from MSI and so far it has been treating me well. After playing around with a few things in Afterburner, installing and uninstalling drivers I realized my fan speed was getting wy too high....up to 100%. However when that happened, my GPU was mostly at 60°C or even under that. Long story short, I did a fresh install on my PC. Completely whiped every SSD and HDD and reinstalled everything and it is happening again.
I am using the new AMD 17.7.2 driver, which is not a beta! So annoying.
Does anybody have any idea what is wrong here? I don't want to mess with anything in Afterburner or anything like that, because I had issues running afterburner in some games.
EDIT: I am talking about a gaming workload, not idle.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/814775-fan-speed-high/
4 minutes ago, emosun said:
is the card at 60c when the fan is at 100%?
If so it means the card is obviously overheating.
Sorry what?
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221680
Set the fan speed to auto in Afterburner or manually set a fan speed curve
1 minute ago, emosun said:
if the card has to run that fan at 100% speed just to keep it's temperature at 60c then something is very wrong with it's cooling system or the gpu is under load somewhere.
Overheating means the card runs too hot. 60 degrees celsius is not hot.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221687
60℃ is not hot, as I previously mentioned the target temperature is 80℃.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221692
Yeah it is , if the fan is at 100%.
The card should be at 30-40 when sitting on the desktop doing nothing , and only hit 60c + with maybe 40% fan usage during games.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221693
15 minutes ago, JamieTurd said:
The OP didn't mention if the card was idle or under load.
15 minutes ago, emosun said:
I didn't see him mention it was during games anywhere either.
16 minutes ago, deXxterlab97 said:
I didn't see he mention it was on idle anywhere.
Sorry guys! ;-)
I am talking about a gaming workload. The GPU turns off the fans when idle and GPU temps are in the 40s then, which is totally fine for passive operation.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221717
1 minute ago, mapegl said:
Sorry guys! ;-)
You can set manual fan speed in MSI Afterburner or custom fan curve
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221720
36 minutes ago, Neutrideo said:
Did you change the fan speed in afterburner??
Nope.
I have not tweaked anything. That's why I thought it should just run at default and F***ING quiet! ;-)
Anyways, thanks all for the lovely suggestions.....I reseated the cooler and put the graphics card back in PC and now it works......for whatever reason. I really don't get it. But it works now.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221860
Just now, mapegl said:
Nope.
That's great!! I hate it when people have pc problems.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221862
28 minutes ago, Neutrideo said:
Mac users on the other hand, I say let them suffer, we will have gpu's raining upon us, whilst the mac users shall have new devices!!!!
What?
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10221938
39 minutes ago, Neutrideo said:
MAC USERS SHALL DIE IN A PIT OF FLAMES!!!!
So you are saying my girlfriend should burn in hell? Thanks man. Appreciate it...
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10222025
2 hours ago, Neutrideo said:
It was a joke... apple doesent really want you to buy parts for their devices, thus they are burning. Geez, I should word my posts better
Sorry. I like messing with people a bit. I really wasn't offended. Seriously.
https://linustechtips.com/topic/814775-fan-speed-high/#findComment-10222715
