Currently im planning to build another pc.
I've already made a pc partpicker list for a build. but im not sure if its overkill in places or missing.
my budget is 1.5k, but i prefer it to be cheaper. and as for color scheme i want a black/green/white build if possible.
but case has to be black overall
PC will be mostly to play AAA titles and streaming/recording.
https://pcpartpicker.com/list/JsxDgL
[PCPartPicker part list](https://pcpartpicker.com/list/JsxDgL) / [Price breakdown by merchant](https://pcpartpicker.com/list/JsxDgL/by_merchant/)
Type|Item|Price
**CPU** | [Intel - Core i7-7700K 4.2GHz Quad-Core Processor](https://pcpartpicker.com/product/VKx9TW/intel-core-i7-7700k-42ghz-quad-core-processor-bx80677i77700k) | $308.87 @ Amazon
**CPU Cooler** | [Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](https://pcpartpicker.com/product/hmtCmG/cooler-master-cpu-cooler-rr212e20pkr2) | $26.88 @ OutletPC
**Motherboard** | [Asus - PRIME Z270-A ATX LGA1151 Motherboard](https://pcpartpicker.com/product/7VZ2FT/asus-prime-z270-a-atx-lga1151-motherboard-prime-z270-a) | $171.98 @ Newegg
**Memory** | [Corsair - Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory](https://pcpartpicker.com/product/3wPzK8/corsair-memory-cmk16gx4m4a2400c14) | $146.99 @ Newegg
**Storage** | [Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive](https://pcpartpicker.com/product/3kL7YJ/samsung-internal-hard-drive-mz75e250bam) | $104.64 @ OutletPC
**Video Card** | [Asus - GeForce GTX 1070 8GB STRIX Video Card](https://pcpartpicker.com/product/GGPzK8/asus-geforce-gtx-1070-8gb-video-card-rog-strix-gtx1070-8g-gaming) | $484.98 @ Newegg
**Case** | [NZXT - S340 - Designed by Razer ATX Mid Tower Case](https://pcpartpicker.com/product/GZfmP6/nzxt-case-cas340wra) | $94.99 @ Amazon
**Power Supply** | [Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply](https://pcpartpicker.com/product/9q38TW/corsair-power-supply-cp9020092na) | $109.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $1459.32
 | Mail-in rebates | -$10.00
 | **Total** | **$1449.32**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-07-29 21:12 EDT-0400 |
Thank you in advance for any help given
https://linustechtips.com/topic/814655-new-build-help/
Get a Ryzen 1700 instead. For streaming, it's miles better than the 7700K. You also won't need the 212 Evo. You could either use the stock cooler, or upgrade to a Dark Rock 2.
Beware that Ryzen likes higher speed memory, so try to get 3000 MHz or faster.
Get a HDD for mass storage.
The Phanteks P400S has RGB LEDs, I think.
Get a cheaper PSU. An EVGA G2 650W or similar
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220427
try this:
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($308.87 @ Amazon)
Motherboard: Gigabyte - GA-Z270X-UD3 ATX LGA1151 Motherboard  ($100.98 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: SanDisk - Ultra II 240GB 2.5" Solid State Drive  ($84.95 @ Adorama)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  ($703.99 @ SuperBiiz)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($79.99 @ Newegg) LEDs can be changed to green.
Power Supply: Rosewill - Capstone 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Other: FSP Windale 6 CPU Cooler 6 Direct Contact Heatpipes 6mm Aluminum Alloy with 120mm PWM Fan (AC601)  ($39.99 @ Amazon)
Total: $1498.75
Generated by PCPartPicker 2017-07-29 21:44 EDT-0400
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220467
Changed to Ryzen and added more storage.
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($289.88 @ OutletPC)
Motherboard: Asus - STRIX B350-F GAMING ATX AM4 Motherboard  ($106.98 @ Newegg)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3400 Memory  ($175.89 @ OutletPC)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($104.64 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8GB STRIX Video Card  ($484.98 @ Newegg)
Case: NZXT - S340 - Designed by Razer ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Corsair - RMx 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1415.23
Generated by PCPartPicker 2017-07-29 21:49 EDT-0400
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220478
Total: $1415.23
no need for more storage cause i already have 2 1tb wd blacks, i think i prefer intel but ill check out ryzen cause i haven't really paid attention to anything about it.
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220535
15 minutes ago, herman mcpootis said:
try this:
Total: $1498.75
i won't be doing for than 1080p gaming. and case needs to be black overall
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220543
It's the first good CPU AMD has made in like a decade.  And it's really really good, especially for streaming.  That build is also RGB capable btw.
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220544
you can cut the 1080ti down to a 1070/80 and get a 144hz/1440p monitor if you want, or just save the money. there's black and white P400 if you want those colors instead.
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220550
He's streaming, he shouldn't be getting an i7.
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220552
didn't notice it earlier.
Motherboard: ASRock - X370 GAMING X ATX AM4 Motherboard  ($110.98 @ Newegg)
Case: Phanteks - ECLIPSE P400 TEMPERED GLASS ATX Mid Tower Case  ($85.98 @ Newegg)
Total: $1495.75
Generated by PCPartPicker 2017-07-29 22:10 EDT-0400
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220563
I've changed it up to include ryzen. does this sound better?
[PCPartPicker part list](https://pcpartpicker.com/list/LNhngL) / [Price breakdown by merchant](https://pcpartpicker.com/list/LNhngL/by_merchant/)
Type|Item|Price
**CPU** | [AMD - Ryzen 7 1700 3.0GHz 8-Core Processor](https://pcpartpicker.com/product/3kPzK8/amd-ryzen-7-1700-30ghz-8-core-processor-yd1700bbaebox) | $289.88 @ OutletPC
**Motherboard** | [Asus - STRIX B350-F GAMING ATX AM4 Motherboard](https://pcpartpicker.com/product/ZHyxFT/asus-strix-b350-f-gaming-atx-am4-motherboard-strix-b350-f-gaming) | $106.98 @ Newegg
**Memory** | [G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory](https://pcpartpicker.com/product/ybrcCJ/gskill-tridentz-rgb-16gb-2-x-8gb-ddr4-3200-memory-f4-3200c16d-16gtzr) | $155.99 @ Newegg
 | **Total** | **$1347.45**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2017-07-29 22:12 EDT-0400 |
https://linustechtips.com/topic/814655-new-build-help/#findComment-10220572
