I have been using razar orachi for several years and it starts to get the double clicking problem and would like to buy new mouse
tried Logitech g502 for few days and i stared getting rest pain so i send it back
I need suggestions for the suitable mouse to replace the orachi
what do you think of the Corsair M65 Pro ? or will it be too large
i use semi-claw grip
https://linustechtips.com/topic/814214-need-advice-on-smaller-mouse/
Just get the same mouse m8, if you like it and you feel comfortable using it. get a new one, easy as that
If you need help on used parts, contact me. I'm an used enthusiast.
Open the spoiler to see some cool stuff!
My old/new tech Collection!
CPUs (11)
Intel Pentium III @ 733Mhz (Oldest of the Bunch)
Intel Pentium 4 @ 2.8Ghz (2002)
Intel Pentium 4 @ 3.0Ghz (2003)
AMD Sempron 64 2800+ @ 1.6Ghz (2004, Aug)
AMD Athlon 64 3500+ @ 2.2Ghz (2004, Jun)
2X Intel Xeon X5355 @ 2.66Ghz (2006, Q4)
Intel Pentium E2140 @ 1.6Ghz (2007, Q2)
Intel Xeon E5630 @ 2.53Ghz (2010, Q1)
Intel Core2 Duo E8400 @ 3Ghz (2008, Q1) (In use, @ 3.61Ghz)
Intel Pentium E6500 @ 2.93Ghz (2008, Q1)
GPUs (6)
Palit GeForce 6800 GS (Should be working, AGP 8X)
Club 3D GTS 450 (Working, PCI-e 16x)
Sapphire Radeon X800GTO (Working, PCI-e 16x)
Nvidia GeForce 4 (Last time worked, AGP 4X)
Nvidia GeForce FX (No idea, AGP 4X)
Gigabyte Radeon HD 7970 OC (Semi-dead, PCI-e 16x)
Ram (1)
No idea of the brand or Socket (Whopping 16 Mb memory)
Cables (1)
CrossFire X Cable
i am trying to explore a new options also the orachi isnt that great really
if i didnt find anything suitable then i will just get the same model again :(
Why not go for a bigger mouse, something that is comfortable and flexable, what is your budget anyway?
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
i think my hand is a little smaller than average (around 6.5" to 7" long) also i have been using the orochi for 5+ years so didn't try anything else long enough to judge (beside the g502 for few days then return it)
around $60
what do you have in mind ?
3 minutes ago, oldnick said:
i think my hand is a little smaller (around 6.5" to 7" long) also i have been using the orochi for 5+ years so didn't try anything else long enough to judge (beside the g502 for few days then return it)
around $60
Defender Warhead GM-1750 Gaming Mouse
Haven't used it personally, but a friend has it he doesn't complain about it. Take a look, maybe you'll like it.
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
Also, take a look at some of The Redragon mouses, but i think they might be a little small for your hand.
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
OOps, sorry i miss understood, i thought you wanted a bigger mouse...
CPUs (11)
GPUs (6)
Ram (1)
Cables (1)
CrossFire X Cable
