This is my set up, when I am playing rust or any game I have unexpectedly low fps for my pc specs. 20-60 fps which is very surprising.
I have updated drivers and bios, I can't understand what is happening and I have no idea how can I fix it.
I am thinking about changing my motherboard. Because I think it might be causing the problem, but do you guys have any advice
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  (£186.00 @ Amazon UK)
CPU Cooler: NZXT - Kraken X31 69.5 CFM Liquid CPU Cooler  (£53.98 @ YoYoTech)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  (£79.95 @ CCL Computers)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  (£146.41 @ Amazon UK)
Storage: OCZ - TRION 150 480GB 2.5" Solid State Drive
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: Palit - GeForce GTX 1080 8GB JetStream Video Card  (£519.98 @ Novatech)
Case: NZXT - S340 (Black) ATX Mid Tower Case  (£62.39 @ Aria PC)
Power Supply: Corsair - CXM 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£79.14 @ Aria PC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Case Fan: Corsair - SP140 49.5 CFM  140mm Fans  (£18.95 @ Amazon UK)
Monitor: AOC - E2460SH 24.0" 1920x1080 60Hz Monitor  (£102.97 @ Amazon UK)
Keyboard: Corsair - K70 RGB RAPIDFIRE Wired Gaming Keyboard  (£154.50 @ Aria PC)
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Kingston - HyperX Cloud Stinger  Headset  (£47.99 @ Novatech)
https://linustechtips.com/topic/813369-low-fps-low-gpu-usage-and-low-cpu-usage/
2 minutes ago, Rushton said:
MSI - B350 PC MATE
Common MSI issue. Check you don't have the bug forcing your CPU to be at 1.55GHz. (Use monitoring software to check)
You've successfully diagnosed this yourself. MSI's ryzen boards are shit and riddled with issues. They pop up on the forum every day. I knew you had an MSI board before reading it.
It's in Beta and the engine it uses isn't that well developed yet
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
Or it could just be Rust being Rust.
Don't really see why the motherboard would be an issue.
Rust is pretty odd like that. One minute you're flying 60+FPS and the other you're crawling at 15.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Could you stop pointlessly bashing MSI's boards without legitimate information?
I'd be getting similarly lower performance if it had anything to do with the board itsef.
AFAIK I have only seen this bug on MSI boards. Lets see if it was that ;)
+ this. Test more than 1 game ofc
In most games I have lower fps than i would expect be it doom or shadow of mordor
Yeah you have proved my point I guessed right 1st time around. I don't know the specific solution to the bug.
Try the following:
Reflash the latest BIOS.
Load optimised defaults
Try again
(don't overclock anything until you confirm stock is functioning correctly)
1 minute ago, Rushton said:
DO you  have a  solution?
Ideally a different manufacturer :P otherwise see above/try reddit. I see this issue a lot on reddit but can't link you from this pc.
@revsilverspine #CalledIt
It's not a bug, it's actually a bad overclock and the board is keeping itself alive.
Funny how all the posts are 2+months old and everything was fixed by a bios reflash.
ITS A BIOS BUG
I didn't do any overclocking at all. i don't even have the inbuilt overclocking on.
1. Was I not right this was limited to MSI? Yes I was.
2. Did I not just tell him to do exactly this? Yes I did. Don't get butthurt with me because their boards are garbage.
3. Spot on diagnosis 1st post without further info. Think that's a new personal best :P
4. There are more recent posts (this one) and others I see them here and on reddit every few days
Edited by tom_w141
Just because a couple older bios versions were buggy it doesn't mean their boards are garbage.
OP is on a current BIOS so clearly the issue is still present.
When I can guess the solution before entering the thread it indicates at least to me that the boards are crap.
@Rushton If you can't resolve your issue and are still within your retailers return period just initiate a refund and buy from literally any other manufacturer.
I  had a very similar issue if not the same and for me installing the latest chipset drivers helped. I am also using an MSI motherboard and was already running the latest bios, but that fixed it for me....actually just yesterday
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
I think i will have to buy a new one. As i have both the latest CPU drivers and the BIOS was reflashed.
