USB sound keeps popping off
Dreaper
Go to solution Solved by AT0MAC,
This should at least stop the sound from happening, edit it to make no sound if disconnect, not solving the actual problem (if any)
One of my machines do the exact same thing and there is nothing wrong its just annoying as f....
I get the usb disconnect sound every 5 mins please help me to turn it off or fix it
So its not like the audio stops working, its just the notification sound that annoys you?
My Gaming PC: 27833
Yea
My Gaming PC: 27833
2 minutes ago, AT0MAC said:
This should at least stop the sound from happening, but not solving the actual problem (if any)
One of my machines do the exact same thing and there is nothing wrong.
How do i disable that?
NVM
There were it says Sounds: Windows Hardware Remove.wav, choose "none"
My Gaming PC: 27833
