Hello LTT forum,
I am very new to windows and pc's, have used macs my whole life but now that I'm in college and pursuing an engineering degree I need some more power. I would be extremely if you all could help me build the best system for what I need to do at a relatively inexpensive price. I use auto-cad pretty frequently and would also like to play some games (PUBG, overwatch, gtaV etc.). What is the best computer I can build for around or under 600-700$ that could easily handle those two things. Ive been watching LTT for approx. 2 years now so I understand how to build a computer but I am overwhelmed by the amount of computer components. Thank you very much for your help in advance, I'm very lost right now.
https://linustechtips.com/topic/811336-pc-build-help/
1 minute ago, PaddyShack07 said:
Nope I already have all of my peripherals, around 600$ purely on the system.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($197.88 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($65.98 @ Newegg)
Memory: GeIL - EVO POTENZA 16GB (2 x 8GB) DDR4-2400 Memory  ($105.99 @ Newegg)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($52.65 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  ($149.99 @ SuperBiiz)
Case: BitFenix - Nova ATX Mid Tower Case  ($27.99 @ NCIX US)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $688.35
Generated by PCPartPicker 2017-07-23 01:30 EDT-0400
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10183990
Total: $688.35
^^ Go for this.
Endorsed by me.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184014
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($78.89 @ B&H)
Motherboard: ASRock - B250 Pro4 ATX LGA1151 Motherboard  ($87.89 @ OutletPC)
Storage: Hitachi - Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card: EVGA - GeForce GTX 970 4GB SSC ACX 2.0+ Video Card  ($150.00)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)
Total: $598.39
Generated by PCPartPicker 2017-07-23 01:45 EDT-0400
I think you dont need too much power on cpu but gpu you need the best of now. Get a used one from ebay, i saw them for 150$ is like a 1060 but 10% less powerful.
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184035
How big of a difference would the AMD Vs the Pentium be?
a huge difference  ones a dual core and ones a 6 core go with the 1600
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184056
if you want to get a cheaper cpu get a 1400
Peripherals
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184070
11 minutes ago, PaddyShack07 said:
Planning on buying @deXxterlab97 build. One last question, need a monitor recommendation. What is the best monitor for the cheapest price. Decided I'm going to upgrade my current ones. don't need 4k or anything fancy not very particular.
what res, size and do you need IPS?
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184105
1 hour ago, deXxterlab97 said:
Who are you that need to endorse my lists? It's perfectly fine on its own already. Thanks.
:P
1 hour ago, Antony Leung said:
This one is acomplishing the 600$ max. if you want more cpu power get a I5 7500.
But, you lose the 6 core and go down to a dual core.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184182
3 minutes ago, Antony Leung said:
I said if he want go higher go for a i5, TBF that pentium is 4 virtual cores anyways. he dont need that many cores for autocad.
Why not a Ryzen 5? With a 1400, it can easily fit into the budget, and you would still have room for a pretty satisfactory graphics card.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184258
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($156.88 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($77.98 @ Newegg)
Video Card: EVGA - GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card  ($200.00)
Total: $716.47
Generated by PCPartPicker 2017-07-23 03:56 EDT-0400
ughh.. 16$ extra. well I saw used 980 for 200 on ebay. so this should be the best you can get. If not get 970 for 150$ and the total should be 668$.. something
https://linustechtips.com/topic/811336-pc-build-help/#findComment-10184333
