I want to upgrade an older desktop I have. I want to put in a Intel Core 2 Quad Processor Q9400. Which i know will fit in my motherboard. But i also want to install a MSI ATI Radeon HD6450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card R6450-MD1GD3/LP. I just don't know if they are compatible with each other.
https://linustechtips.com/topic/811296-cpu-motherboard-help/
It should work just fine as long as you have room in the case and the PSU can handle it which it should be able to.
i5 6600k @ 4.4ghz on Hyper 212 Evo
Powercolor RX 480 8Gb Red Devil @1330Mhz
Bottom line:  Don't be a spaz or an 800lb gorilla when installing your expensive CPU, and you won't have any problems. --Phate.exe
https://linustechtips.com/topic/811296-cpu-motherboard-help/#findComment-10183483
