Posted July 22, 2017 hi guys im new in the pc world and i decided to bulled my self a top of the line ryzen pc and i want to coustem loop it ifind akit from Thermaltake Thermaltake Pacific RL240 D5 Hard Tube Water Cooling Kit with 2 Red Riing Case Fans and Red Coolant 240 m radiretor and iwant to cool just my cpu so what u think gyus mmy cpu is amd ryzen 1700 Link to comment https://linustechtips.com/topic/811008-hard-tube-water-cooling-kit/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 22, 2017 Your title mentions hard-line tubing but the kit you mention is a soft tubing kit. Do you want soft tubing? Current Network Layout: Current Build Log/PC: Storage Server Setup: Prior Build Log/PC: Link to comment https://linustechtips.com/topic/811008-hard-tube-water-cooling-kit/#findComment-10180530 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 22, 2017 Author 2 minutes ago, Lurick said: Your title mentions hard-line tubing but the kit you mention is a soft tubing kit. Do you want soft tubing? no actually ilike hhard tubing Link to comment https://linustechtips.com/topic/811008-hard-tube-water-cooling-kit/#findComment-10180537 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 22, 2017 Thermaltake radiators are aluminium, wouldn't recommend it. Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment https://linustechtips.com/topic/811008-hard-tube-water-cooling-kit/#findComment-10180573 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 22, 2017 Feel free to browse all of our hard tube complete watercooling kits here! Theyre a great way to get into watercooling! Link to comment https://linustechtips.com/topic/811008-hard-tube-water-cooling-kit/#findComment-10182433 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
