Audio Dac Q and A's
Billy_Mays
#1       Q: My mic and possible speakers I need to have 48v for my mic (https://www.amazon.ca/gp/product/B00XJF59X6/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
           A: (You guys suggest one)
#2      Q: My budget is $100 snow pesos (shipping and tax included)  because I only want to spend $300 after my new PSU possibly if I cant fix my system crashing by this weekend  and for a new monitor (stuck at 900p :(
          A: (You provide answer again)
So what can I get for my sound system
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
17 minutes ago, lw88 said:
What did I just read?
I want to have my mic working and I only want to spend less on it but want to provide what my mic needs
Can try to rephrase your question a little more straight forward? I have literally idea what you are actually trying to ask here haha
I want a decent dac that can support 48v for my mic and I also need it to have speaker inputs so I can listen to my speakers if I get them
Check out the Scarlett Solo - should be able to run your mic from that and have monitor out as well
Ok I'll check the prices
