Hello guyss.
I got my OnePlus 5 and with it i got dash charger, advirtised at 4 amps... Now im thinking... What if i use this charger with my other devices that cant support 4 amps... What will happen? Can i damage my devices with that charger? How it works?
Thanks for any respond, love you guys
https://linustechtips.com/topic/810408-batteries/
Devices will only take what they need.
Amps is not the problem. Voltage is. :3
Unless the device is asking for more amps than the charger can provide. Then you have a problem.
https://linustechtips.com/topic/810408-batteries/#findComment-10173752
