My CPU is being used and is almost always at 100%. My RAM usage is sometimes high as well. Im not sure if my CPU is broken or something. Here are some screenshots to answer any questions. My CPU stays at sub 40 Celsius constantly.
https://gyazo.com/a8e52a161a671f072af30f67cfec4abb
https://gyazo.com/68050edc3b7c0d4d2736b64cf5af2155
https://linustechtips.com/topic/810317-help-please/
Run a virus scan. If it doesn't catch anything, check your background processes and kill apps you aren't using.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/810317-help-please/#findComment-10172873
Just now, Azriel said:
Will do, but is the 801MHz normal?
Not really, but I can't see any context, so IDK if it's idling or something.
Mouse: EVGA X17
https://linustechtips.com/topic/810317-help-please/#findComment-10172891
Do you have a ton of programs running?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/810317-help-please/#findComment-10172901
1 minute ago, ArtoriaPendragon said:
Wait. Your 4690k is at 100% load and it's only at 801 MHz? That doesn't seem right at all -  have you messed with the power settings or have an offset mode for your CPU clock?
I honestly have no clue what that means. Could you explain that please to me? I'm so sorry for my ignorance.
https://linustechtips.com/topic/810317-help-please/#findComment-10172943
the 801 MHz is what's wrong
go in bios and try setting everything to default or locking it to 4GHz (i think that's slightly under default turbo clock)
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/810317-help-please/#findComment-10172954
1 minute ago, Azriel said:
Don't I restart my computer to launch the bios menu?
yes
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/810317-help-please/#findComment-10172965
Your CPU is supposed to run at a certain speed. Yours should be running at 3.5 GHz (~3500 MHz) and turbo up to 3.9 GHz as needed but it's at 801 MHz
https://linustechtips.com/topic/810317-help-please/#findComment-10173004
Would you mind explaining how to change my CPU speed through the BIOS menu?
https://linustechtips.com/topic/810317-help-please/#findComment-10173010
it's kinda hard to get screenshots of bios... so turn off PC. turn it on and mash the del button. then you switch the bios to advanced mode (often f7 key)
then you should see an OC tab. set the ring ratio also could be named clock multiplier to 39
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/810317-help-please/#findComment-10173029
BTW if you're doing what Squinty suggests and you're using an ASUS motherboard, the tab will be labeled as AI Tweaker.
https://linustechtips.com/topic/810317-help-please/#findComment-10173046
Good looking! I am actually using an ASUS z-97a. I'm still confused somewhat. Sorry! Here are the things that I see in the Ai Tweaker.
https://gyazo.com/7ba1059c3d8a90a01298d8e35e2048ba
https://gyazo.com/f5489def1a9f877aee13a1d83997bbd8
https://gyazo.com/6702ead52dfd62169466c192635c62fc
https://gyazo.com/d6c91148ef447e422d6c6928ded5a389
https://linustechtips.com/topic/810317-help-please/#findComment-10173084
