plz help me becuz i dont know how much vram i need!!!!
Solved by Armakar,
You seem to be confused. You can't pick exactly how much VRAM you want, the cards come with a set amount.
You can't have a 3GB 1050 or 1050Ti, you can't have a 4GB 1060, they come set.
The 1050 is 2GB, the 1050Ti is 4GB, the 1060 comes in 3GB and 6GB variants, 1070 and 1080 come in 8GB, 1080Ti is 11GB and Titans come in 12GB.
I'd reccomend either a 1060 6GB, 1070 or an RX 580 (8GB version). All those cards are killing it at 1080p at the minute and will do for some time.
