Need help
Go to solution Solved by Saddy,
Rendering requires a lot of CPU power, so I would recommend of getting the 1600 as it is only 20 more dollars. Also here is a comparison
http://cpu.userbenchmark.com/Compare/AMD-Ryzen-5-1600-vs-AMD-Ryzen-5-1500X/3919vs3921
Hey guys,i am very tight on budget i have 2 choices which would you prefer ,now i am going to use these for rendering and editing,music production which would u suggest
1) asus prime b320 k Motherboard and ryzen 1600
2) asus prime b350 k Motherboard and ryzen 1500x
https://linustechtips.com/topic/809850-need-help/
If this post solved your problem, please press the check below :).
https://linustechtips.com/topic/809850-need-help/#findComment-10167673
Dont eat for a week and get the B350 with 1600
Everyone on here be showing off their rigs, so here I go:
Main Desktop CPU: Ryzen 1600 @ 3.65 GHz Memory: 2x8GB @ 3200 MHz Graphics: NVIDIA ASUS 1070 MOBO: ASRock Fatal1ty AB350 Gaming-ITX/ac Storage: NVME M.2 Crucial P1 SSD; SATA Crucial MX500 SSD; Seagate BarraCuda HDD.
Acer Aspire 5755G CPU: Intel i5-2410M @ 2.30GHz Memory: 6GB DDR3-1066 SDRAM Graphics: NVIDIA GT 540M 2GB Storage750GB 2.5" 5400RPM HDD Display15.6" 1366x768
https://linustechtips.com/topic/809850-need-help/#findComment-10167690
Go for the 1600, though a B350 mobo would a lot better than a a320 board.
Even a 3.8ghz OC would get you quite a bit of free performance.
Maybe skip lunch for a couple days to save the extra 10-20 bucks?
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/809850-need-help/#findComment-10167698
(Please note us here at Linus Tech Tips do not agree with the skipping of eating to buy computer hardware)
https://linustechtips.com/topic/809850-need-help/#findComment-10167711
