No power
Go to solution Solved by ZenMonkey,
I was able to get it working. Thanks for the help.
I was running an ITX build, but front panel on my old case stopped working. I didn't like the heat of a SFF gaming rig, so I bought a new case and motherboard (Phanteks Eclipse P400S and ASRock Fatal1ty Gaming Z97X). Everything else was working, so I transferred everything into the new case and motherboard last night. When I push the power switch, nothing happens. There's no power at all. I disconnected the 24 pin and 8 pin ATX power cables to the motherboard and reseated them, but that didn't fix it.
I don't have a voltmeter, but the power supply was working fine three days ago. What are some steps I can try before I resort to completely disassembling and reassembling the computer?
Also, the P400S front panel connectors had a SATA power connector, but the panel just two USB 3.0 and a the audio in/out 3.5mm slots, the power/reset button, and a fan controller button. It looks like it's connected to a daisy chain of fan connectors to power the front fans and fan controller button, but I'm not 100% certain. I plugged it into one of my SATA power cables, which only has one 3.5" drive attached to it. Can SATA power case fans? I checked the user manual but couldn't find an answer. Anyone familiar with this case that can elucidate for me?
https://linustechtips.com/topic/808726-no-power/
3 minutes ago, Colin Donoghue said:
Sata connector is for the fans
the SATA power connection from the PSU is for the RGB lighting
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/808726-no-power/#findComment-10155296
