Look good, no issues.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/808490-final-build-check-up/#findComment-10152675
It's rather good, but I'm curious on what you plan on using this PC for. If you ever want to SLI, I'd bump that unit up to 850W.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/808490-final-build-check-up/#findComment-10152693
Just now, Mc1002D said:
I'm going to be just gaming + streaming on the side. with maybe a bit of content creation.
Alright, sounds good. You could get away with a lower wattage PSU. Otherwise, the build is fine.
https://linustechtips.com/topic/808490-final-build-check-up/#findComment-10152719
The PSU was on sale so that's why I bought it
That's fine, it was really only a suggestion to save a few pennies.
https://linustechtips.com/topic/808490-final-build-check-up/#findComment-10152747
1 minute ago, Mc1002D said:
Will my cooler be good enough for OC and streaming?
Yes, with a bit of luck, you should be able to reach 4GHz stable.
https://linustechtips.com/topic/808490-final-build-check-up/#findComment-10152769
