Hey, I posted about my Razer Blade having issues earlier today, but I seem to have narrowed down the issue to the battery. In event viewer, the shutdown reason is "Battery." I'm not sure why it would go into hibernation because of a low battery when the battery is at 97%, so it must be some Windows safety thing. I read somewhere that Windows will do this if the battery voltage goes down too quickly, but I'm not sure how I'd fix it. I found this post while looking for other people having this issue, but my power settings are already set to the defaults. (10%, 5%) Is there any other settings I can change to prevent this from happening? It seems to be software related.
https://linustechtips.com/topic/808410-battery-shutdown-at-97/
goto control panel
open power options
advanced options
now find battery settings anything here that be changed?
check hibernate/sleep options as well
https://linustechtips.com/topic/808410-battery-shutdown-at-97/#findComment-10151587
