my router died and im using a shitty 2006 airport from the thrift store in the mean time but it keeps locking up and i have to unplug it and plug it back in (multiple times a day)
as far as I can tell dhcp is whats locking up
anyway
I want to use linux to do a router instead of buying a router but I dont want to use pfsense because of its shitty wireless support.
I think im going to put debian on it.
I want to buy this barebones pc and put the max ram in it.
I have chosen it because it is the cheepest barebones i can find that has dual nic's and wireless and doesent need too much else to get running
https://www.newegg.com/Product/Product.aspx?item=N82E16883218075
I want to get that and get ram from the electronics thrift store called grey bears in my area.
http://www.greybears.org/thrift-store/computer-store/
so my software setup would need to be...
eth0 WAN
eth1 LAN (to switch)
WL0 LAN (broadcast network for wireless devices to join)
how hard would this be to do?
does anyone have any advice?
does that boneless have any fatal flaws i should know about?
im probably going to use it as a database and MQTT/node-red server as well if that is possible ontop of its routing
cTurtle98 - Desktop
CPU: i7 7700k
COOLER: Thermaltake - Water 3.0 Extreme S
MOBO: Asrock z270 killer sli/ac
RAM: G.Skill Trident Z 32 GB (4 x 8 GB) DDR4-3200
SSD 1: Intel - 600p Series 1TB M.2-2280 (Windows)
SSD 2: Samsung 970 Evo 1 TB M.2-2280 NVME (POP_OS)
GPU: MSI - GTX 1070
PSU: EVGA - SuperNOVA G2 550W 80+ Gold Fully-Modular
CASE: Thermaltake - Versa H26
cTurtle98 - Portable PC
CPU: R5 1600
COOLER: NH-L9a-AM4
MOBO: ASRock - AB350 Gaming-ITX/ac
RAM: 16GB (2 x 8GB) Corsair - Vengeance LPX DDR4-3200
SSD 1: Intel - 600p Series 512 GB M.2-2280 (Windows)
SSD 2: 860 Evo 1 TB 2.5" (Manjaro)
SSD 3: PNY - CS1311 120 GB 2.5" (POP_OS)
GPU: Gigabyte GeForce GTX 1650 4 GB MINI ITX OC
PSU: HDPLEX 400 AC-DC DC-ATX Combo
CASE: NFC Skyreach 4 mini
https://linustechtips.com/topic/808405-linux-router-questions-and-advice/
28 minutes ago, unijab said:
Are you familiar with iptables?
yeah its the firewall program installed by default on debian
cTurtle98 - Desktop
CPU: i7 7700k
GPU: MSI - GTX 1070
CPU: R5 1600
COOLER: NH-L9a-AM4
