So I just recently built my first pc using the Ryzen 1500x.
When i was playing a pubg game I noticed i was getting a drop in fps.
I assumed it was my cpu and realized i hadn't fully secured the cpu cooler.
I just downloaded a cpu monitor app and was noticing a really wide range of temps.
Can someone please tell me if this is normal or i have something wrong with my pc.
https://linustechtips.com/topic/808364-ryzen-1500x-cpu-overheating/
Core Temp is buggy with Ryzen. Use the AMD monitor tool: https://www.amd.com/en/technologies/ryzen-master
Community Standards
"Beast Mode"
Dedicated Streaming Rig
use ryzen master or NZXT CAM for monitoring temps for ryzen, some programs can display up to a 20c difference from what the temps really are
Yep. Thats perfectly fine.
Community Standards
"Beast Mode"
1 hour ago, HZapperz said:
Using ryzen master idle its at around 43 degrees celcius, using light programs like chrome its at about 55 and when i used cinebench it went up to 71 degrees is this normal?
hmm that's considerably hotter than the 1600 i am running (stock clock right now), idle or just browsing/streaming,  it never really passes 45 degrees wit hthe stock heatsink on 50% fan speed. While gaming and streaming video it reaches around 55 degrees. You might wanna try replacing your thermal past and see if that helps a bit.
The FPS drops you get in PUBG are because it's still a pretty badly optimized game, not because your processor is overheating. I use a 1600X at 4.0 GHz and a GTX 1070, and my FPS fluctuates as well. It fluctuated on my old rig sporting an i7-980X, and it fluctuates on my friends' rigs which use 6700K's and 7700K's.
There's no issue. You're good.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
